Fuel issue
Old Sep 8, 2013 | 08:53 PM
fluffysheeboy's Avatar
fluffysheeboy is on a distinguished road
Default Fuel issue
My girlfriends 2001 Chevy Blazer LT stopped running. She was doing a long drive and it bogged out for a little bit and then proceeded back to normal. For awhile it would take 5-10 times to try and start it to get it to start, but not it wont start at all. I checked all the electrical and getting spark and everything fine there. I poured a little bit of gas into the throttle body and it started right up and died real shortly after gas burned out. I checked if i was getting pressure after the fuel filter and it was plenty (didn't use a gauge but looked fine). So i checked the little pressure valve before it enters the engine and always has pressure there. So its getting fuel all the way up to the engine but for some reason not running. I don't have a shop manual or a good diagram to figure out what else could be the problem so i am coming here for some better help. I'm not familiar with this engine so any detailed advice or help would be very appreciated. Thanks a bunch guys.
Old Sep 9, 2013 | 08:07 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
the problem is the truck needs a minimum of 50psi to run, 30psi looks like alot of pressure but is not enough to run the truck. A fuel pressure and leakdown test would be nessesary.
Old Sep 25, 2013 | 06:44 PM
I tested it and im holding around 50 psi. I now believe its a problem with the injectors. What system controls the injectors and any ways of testing? Thanks for the help
Old Oct 1, 2013 | 06:35 PM
blazerontwenties's Avatar
blazerontwenties is on a distinguished road
Sounds like my problem don't replace plugs and wire rotor or cap of course you can but won't fix.... I've even tested the fuel pressure and got 50 psi as well only thing I can you think of is injectors
Old Oct 1, 2013 | 07:19 PM
50lb_cat's Avatar
The minimum is 55, you also must check the leakdown, it needs to stay above 55 for at least ten minutes.
Old Oct 1, 2013 | 08:38 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
I've got the same issue going on too. But I have already done the plugs and wires. Next I need to do cap and rotor cuz it looks like a chia pet growing on the terminals from all the misfires I've been having. I have already replaced the fuel pressure regulator. And when I test it I have sixty psi but falls quickly to 30 so I don't know if its the pump or injectors
Old Oct 1, 2013 | 09:19 PM
Dang ethanol gas is the root to this issue as for psi I get soooo many different answers its got me confused some say 50 to 60 some say 55 to 65 and 60 up I don't know which is correct I'm going to inspect my injectors next and let you know if that is the fix
Old Oct 2, 2013 | 06:53 PM
yeah im almost positive its a leak in the Fuel Pressure Regulator. ill be inspecting it for a leak shortly. I know its not a electrical issue, already cleared that.
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
95jblaze
Aug 27, 2011 03:46 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
