Fuel pressure?????cpi
Old Nov 17, 2008 | 10:04 PM
caddy500's Avatar
caddy500 is an unknown quantity at this point
Default Fuel pressure?????cpi
What should my fuel pressure be when I turn the key on then off?
Old Nov 18, 2008 | 08:14 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: Fuel pressure?????cpi
Depends what vehicle you're asking about...
Old Nov 18, 2008 | 08:17 AM
For a CPI motor, 55-60psi is the required pressure for the poppet nozzles to actuate (as provided by the FSM for a 95 Blazer CPI).
Old Nov 18, 2008 | 10:24 PM
caddy500's Avatar
Ok I checked my fuel pressure today. When accerlerating my gauge bounces between 40 and 60 psi very rapidly. Idling its fluctuating between 50 and 54 psi. When I put the fuel pump in i just used a piece of fuel line to connect the pump to the sending unit. should I install the Damper or pulsator.
Old Nov 19, 2008 | 08:13 AM
What problems are you having that you are attributing to fuel supply? Related to your other thread??
This is a good example of why things should be kept in one thread so that these types of questions do not have to get asked...
The fluctuation in pressure is normal. For it to drop all the way to 40psi while accelerating is a bit troubling.
When was the last time you replaced your fuel filter?
Old Nov 19, 2008 | 08:29 PM
caddy500's Avatar
Just changed fuel filter last week with no change. I just ordered the pulsator today from napa. I will install it this weekend. Maybe I got a fuel pressure regulator issue? I did put a new one in when I installed the engine. Thanks for your help!!!
prbjeepin
Apr 8, 2013 10:14 PM
MuddyWater87
Apr 25, 2011 09:57 PM
swartlkk
39
Feb 20, 2010 09:39 PM
scottyk
Jun 23, 2007 04:13 PM
