Fuel pump 2 / 3 outlets
Old Feb 18, 2014 | 03:31 PM
alain007's Avatar
alain007 is on a distinguished road
Default Fuel pump 2 / 3 outlets
Hi,
It has been a while but the Blazer in Holland is getting there!
I have now a question about my fuel pump. In that region it quite smells so I am guessing my pump is leaking internally (no spills visible). I want to replace it with another pump that I have, but there is a difference. Currently my pump has 3 outlets, so including return line. The other pump only has 2. Can I just use that 2 line pump without making any adjustments or is this going to give any problems?
Btw, it is a 350 engine.
BR
Alain
Old Feb 22, 2014 | 11:49 PM
cballard8's Avatar
cballard8 is on a distinguished road
If you want to replace it, I would stick to the 3 line pump. The 3 lines are outlet, inlet and vent and all are important. Is there any loss of pressure or are you wanting to replace your fuel pump based solely on smell? If all else is fine, you may just want to leave it if there is not any obvious leakage.
Old Feb 23, 2014 | 02:04 AM
alain007's Avatar
Thanks for the answer. I yesterday found out that it is probably not the pump but a small leak in the line near the tank, so I need to replace the lines. Apparently fuel smell carries a long way
BouncingRadical
14
Nov 27, 2015 12:30 AM
g_mike
Jan 13, 2011 12:22 AM
rhietpas
Dec 14, 2010 11:04 AM
trailblazer333
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jun 24, 2007 09:41 AM
mytruck2
Dec 13, 2006 04:50 PM
