Fuel pump
Old Apr 12, 2009 | 08:18 AM
grumpys99's Avatar
grumpys99 is an unknown quantity at this point
Default Fuel pump
Not sure if this was the right place to post this ,sorry. Anyways i have a 99 blazer LS, the other day ran fine till i turned it off, all i get is a crank.I can hear the fuel pump but after a few seconds i hear like a air leak from inside the fuel tank. Is the pump damaged? And if so what would the best way to go? can i rebuild for cheaper price or spend aver 200.00, how else can i tell, any help would be good. thanks
Old Apr 12, 2009 | 09:53 AM
bandidolenny's Avatar
How many miles? When was the last time you changed the fuel filter? Put a fuel pressure guage on it and turn on the key. If no pressure then you have lost the pump. Don't buy a cheap pump! Go with a Delco or AirTex.
Old Apr 12, 2009 | 10:29 AM
grumpys99's Avatar
Bought the car with 74000, I have 123000 on it now, but we replaced the pump and filter somewhere around 90000
Old Apr 13, 2009 | 08:09 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Airtex pumps are junk...at least for these vehicles. Only Delco unless you want to do it again sooner rather than later.
Old May 17, 2009 | 11:44 AM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
You def. need a new fuel filter, but im not sure about the pump its sugessted to put a new filter in every 15,000 if i remember correctly, better to replace them often then get something clogged cause they are like 12$
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
