Fuel pump going bad??
Old Aug 4, 2007 | 05:33 AM
iamin402's Avatar
iamin402 is an unknown quantity at this point
Default Fuel pump going bad??
Yesterday my wifes 2000 Blazer would not start i got in and turned the key on thinking it would be that security problem with the key again but i imediatly noticed that the fuel pump did not cycle on (did not hear it kick on) so i also tryed cranking it to see if there was any fuel PSI and there was some in the Rale but none came out when i had the shrader valve depressed wile cranking
Anyways we towed it to a repair shop where my friend works but i decided to crank the engine again after towing it there,
it started..................
Would this be a sign of a bad fuel pump or something eles
Old Aug 4, 2007 | 01:49 PM
blazinloud's Avatar
Default RE: Fuel pump going bad??
could be a bad pump.......sometimes you can get a few starts outta them......
dont forget to check the fuel filter also........
Old Aug 5, 2007 | 11:54 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Yes. Fuel Pump. Same thing happened to me about 3 weeks ago. Wouldn't start and then after it got towed, it started there. The tow jostled the pump around which will normally get another start out of it. (That's why they tell you to hit the tank if you just need to start it to drive it to the shop.) I suggest changing it immediately before it dies on you while you're driving.
BouncingRadical
14
Nov 27, 2015 12:30 AM
spittybays
Nov 3, 2012 04:12 PM
Boopappa
Aug 23, 2009 08:58 PM
ndekens
Apr 4, 2009 03:50 PM
Smoked
42
Apr 2, 2008 07:42 AM
