fuel pump not getting power
Old Jan 10, 2012 | 02:24 PM
chevyboy90's Avatar
chevyboy90 is on a distinguished road
Default fuel pump not getting power
hey guys i recently had some fuel related problems with my 2002 zr2 2dr blazer stock 4.3 vortec 4x4 the truck cranks but will not start its done this last year and i replaced the fuel pump with a new one my dad recently took it out and it quit on him i was just looking for some steps and diagnosis help to findout what the problem is any help is apreciated thanks.
Old Jan 10, 2012 | 03:49 PM
pettyfog's Avatar
In the underhood fuse block, locate the FP fuse and relay, check fuse. if both sides have 12v, find relay.. the adjacent one is the horn relay. Make sure they are same relay and swap. Still no FP, then have asst turn key to on and see if FP relay clicks.
If clicks, locate pin 87 socket.. be careful you have to transpose from side to bottom of relay then to relay connector in fuse block. Make sure!!!
Once sure no voltage on that socket, ohm it to frame/chassis/batt grd. Should be less than 10 ohms
Old Jan 10, 2012 | 04:08 PM
xgiovannix12's Avatar
the fuel pump should be on the ecm fuses
I think your truck has 2 ecm a and ecm B
Old Jan 10, 2012 | 05:22 PM
chevyboy90's Avatar
thanks guys ill look into those when i go back i hope the pump aint bad i bought it brand new bout 9 months ago surely it wouldnt be bad would it?
Old Jan 10, 2012 | 05:24 PM
depends
what brand did you use ?
aftermarket pumps last around that time line in these trucks
some last 2 weeks to 9 or 12 months
We recommend you use delco or delphi brands
Edit: when you say you hope its not the pump
did you test the harness at the tank for power ?????
Old Jan 10, 2012 | 05:30 PM
chevyboy90's Avatar
Acdelco and yeah harness was tested the harness no power was getting to the pump
Old Jan 10, 2012 | 05:34 PM
I would not think its the pump then since you have no power in the pigtail
you might wanna start studying the wiring diagram pettyfog provided for you
Old Jan 10, 2012 | 05:35 PM
chevyboy90's Avatar
alright thanks will do giovanni
Old Jan 10, 2012 | 07:40 PM
Gale's Avatar
Gale is an unknown quantity at this point
Ours did this when the crankshaft indicator plug came of at the crank shaft sensor.
Old Jan 11, 2012 | 11:58 AM
millford's Avatar
millford is on a distinguished road
Try replacing the fuel pump relay,$20 worth a shot,also could be the contact in the relay receptacle this was my problem .
