Fuel pump oil pressure switch
Old Nov 27, 2009 | 06:43 AM
robkolo1's Avatar
robkolo1 is on a distinguished road
Default Fuel pump oil pressure switch
I have a 95 4 door, 4.3 Vortex. I went out to start it and it cranks over but its a no start. The relay clicks but the service engine light stays on and the check guages stays on also, as I have been researching this problem, I'm thinking thats its the oil pressure switch can anyone give me any Ideas on how to test the switch? and where is it located? I have a hanes but it is not specific on the location or how to test it, it just says that if the oil pressure drops below a certain level it will cut the pump. Thanks in advance for any help......
Old Nov 27, 2009 | 10:40 PM
jigger's Avatar
jigger is on a distinguished road
The oil pressure switch should only cut the fuel after the engine is started. When you first turn the key to "on" you should hear the pump run for a few seconds to get up to pressure then it will stop. If it isn't putting out enough pressure it won't start. Do a fuel pressure test-autozone has loaners. Also check the filter, they can cause the pressure to be below specs if it is clogged.Also check the fuel pump relay.
sbrookover
Dec 25, 2009 02:42 PM
bmoehrke
Aug 7, 2009 03:58 PM
willysboy2001
Jul 23, 2009 10:21 AM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
