fuel pump problems HELP
Old Nov 20, 2009 | 05:58 PM
elcoomagnifico's Avatar
elcoomagnifico is an unknown quantity at this point
Default fuel pump problems HELP
so i am on my 3rd fuel pump in about a year and it just went out on me again. Does anyone have any idea why my 99 blazer is eating threw these fuel pumps??? i did notice that i had to crank it over more then usual
Old Nov 20, 2009 | 05:59 PM
rriddle3's Avatar
What were the brands of those three fuel pumps?
Old Nov 20, 2009 | 06:24 PM
02BlazerS.jersey's Avatar
02BlazerS.jersey is an unknown quantity at this point
I had the same problem. I went thru two fuel pumps one only lasted two days. I found out that the factory plug that goes into the pump assembly tends to get loose or have burned out plug ends ( due to the small connections). I bought a new drop in assembly which included the sender unit and new installed fuel pump also came with a new "improved" connector pigtail which you have to cut your's off and wire in the new plug end on it. I got it at Autozone near my house was kinda pricey $310 (bout $270 for the 4dr model), but never had a problem since the name of the manufacture was "AIRTEX". Hope this helps you out!
Old Nov 20, 2009 | 06:27 PM
BonestockZR2's Avatar
BonestockZR2 is on a distinguished road
Yup, gotta replace that pigtail. Smash the connector full of dielectric grease, and you should be good to go. I went with Airtek as well.
Old Nov 20, 2009 | 06:41 PM
i do not remember.. i know they were a cheaper replacement part..
can i buy this pigtail anywhere?? like auto zone or checkers?
is this what i should be looking for??
http://www.autozone.com/autozone/cat...=Airtex+Master
Last edited by elcoomagnifico; Nov 20, 2009 at 06:54 PM. Reason: CONSECUTIVE POSTS
Old Nov 20, 2009 | 07:00 PM
Unfortunately, you're prolly gonna get hosed on this one. The pigtail has a different style connector than what is on the adapter in the original pump assembly. You will probably need to buy an entirely new pump assembly in order to change the connector. Its stupid, but that's how they get you to buy their parts.
However, the change in the connector was part of a TSB in the early 00's I believe. So you may want to check with the boneyards to see what they have for fuel pumps. Then you could get a perfectly good fuel pump with new pigtails, b/c many blazers have been dumped during cash 4 clunkers. A majority of them prolly have replacement pumps (with new connectors and pigtails)in them b/c the original pumps were garbage and needed to be replaced.
If you don't want to do that, and can wait a couple of days for shipping, order a new pump from rock auto. It's like $220 compared to the $300+ you'll pay @ autozone. Don't go to Pep Boys - THEY SUCK!
Old Nov 21, 2009 | 08:20 AM
thanks for all the help guys.. found out the problem and it is the plug that goes into the fuel pump....must be going out or shorting out a little bit.. messed with it a lil bit and the pumped kick in so im gonna ask around to see if i can replace it
Old Nov 22, 2009 | 08:02 PM
moldeck's Avatar
moldeck is on a distinguished road
make sure you change the fuel filter.. if it is clogged, you will burn out your pump.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
