full throttle when started up
Old Nov 17, 2012 | 11:55 AM
NEW YORK BOY's Avatar
NEW YORK BOY is on a distinguished road
Default full throttle when started up
my truck just had some motor work(head gasket) about 2-3 weeks ago and ever cents is hasn't ran right.. would take 6 time to get it started and wanting to cut off just a mess.. well today i went to start it and the same. start cut off start cut off and so on. when i got it to stay running it just goes full throttle like and have no control over it.. i just dont know anymore with this truck. and btw the guy i had do the work his shop just got closed down..
Old Nov 17, 2012 | 12:31 PM
rriddle3's Avatar
I would check the fuel pump pressure and Idle Air Control .
Old Nov 17, 2012 | 01:06 PM
ok i will but, i was looking and i seen this. it seems to be broke and it goes behind the intake but have no close what it doseName:  image.jpg
Old Nov 17, 2012 | 10:12 PM
anybody know what that part is/dose?
Old Nov 17, 2012 | 10:28 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
does the other end of that go to the PCV valve?
Old Nov 18, 2012 | 10:04 AM
It goes into the brake booster
Old Nov 18, 2012 | 10:24 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
That's how the brake booster gets it's vacuum, fix it and u will it should be able to run I better believe it does to the intake though.. I'll check.. What is the vehicles info
Old Nov 18, 2012 | 10:25 AM
4X4GS10B's Avatar
its right beside where the spider injector electrical connect to on top of the upper intake..
Old Nov 18, 2012 | 04:32 PM
is this whats making it go full throttle?
Old Nov 19, 2012 | 05:03 AM
4X4GS10B's Avatar
Start there, and see where it takes you..
