Gas mileage plummets - do I have a bad TPS?
Old Jan 29, 2013 | 10:42 AM
scubacamper's Avatar
scubacamper is on a distinguished road
Default Gas mileage plummets - do I have a bad TPS?
My gas mileage does not appear to be what it should be. After driving 40 miles on full tank, the gauge shows 3/4ths full. At 18mpg, in a 19-gallon tank (2dr model), I should get somewhere around 342 miles out of a tank, which should also be about 85.5 miles for every quarter-tank.
This appears to mean that I'm getting more like 9 or 10 mpg; and I drive like an old geezer.
The reason I suspect the TPS is when I'm cruising down the road and barely have my foot on the gas, the throttle speed sometimes hops up & down between 1500 and 2500 rpms.
I was reading a previous post about "gas mileage nightmare", which was helpful in finding some possibilities, but I'm not sure where to begin on my Blazer.
Your help is greatly appreciated!
Old Jan 31, 2013 | 11:26 AM
Default Other thread
I have found some suggestions via this thread:
https://blazerforum.com/forum/2nd-ge...mileage-23431/
Old Feb 2, 2013 | 10:53 AM
Default throttle issue
I continue to have the hopping up and down of the tachometer when the motor is "locked down" (5th gear?), and when I barely have my foot on the gas - it's almost as if the motor doesn't know which gear it wants to be in.
I bought a TPS but haven't decided if I should replace it yet.
In addition, my gas mileage has been terrible - 14 mpg (211 miles over 14.5 gallons).
I don't know if this means anything but I've never seen it before - the last time I filled up, I noticed the cap was wet with fuel on the inside.
I just replaced the fuel filter & put Lucas fuel treatment in, as well as cleaned out the MAF Sensor with CRC cleaner.
motor mount & front o2 sensor was replaced 6,000 miles ago.
motor was replaced 60,000 miles ago
Sending Unit & Fuel pump replaced 60,000 miles ago
Old Feb 11, 2013 | 03:53 PM
Any ideas?
I replaced the TPS and got slighty better performance, but still have the fluctuation of the throttle as previously mentioned...
Old Mar 7, 2013 | 07:12 AM
rpswift's Avatar
rpswift is on a distinguished road
Default Surging/stuttering and fuel economy-
I had a similar issue with my '98 Blazer S10 4.3 4WD with 215k on the original engine/transmission. Fuel economy was only 18 mpg or so when I bought it new, but I spend a lot of time sitting in Seattle traffic at 0 mpg... I noticed a stuttering problem about two weeks after replacing the intake manifold gaskets - one rotted-out due to DexCool (regardless of what anyone says), but my coolant leaked externally.
Based on information provided in various threads here, I first replaced the distributor. There was a worn bushing and almost 2mm of axial 'play'. This did not fix the problem, and I had a P0122 DTC thrown with increasing frequency. Replacement of the TPS appears to have fixed the problem - only one week in, but no surging/stuttering. I noticed this behavior at constant sped/minimal load with the transmission in 'OD'. I tried light pressure on the brake pedal to evaluate torque converter lock-up without success. The behavior would be observed in '3rd gear' as well.
When I replaced the TPS I noticed a fair amount of 'wobble' in the rheostat even though static resistance/voltage measurements were within specifications.
My engin now idles around 550rpm, but previously was around 7-800rpm. From my recent fill-up, I was around 16mpg.
This is a little off-topic, but the TPS appears to be a critical sensor that has significant effect on engine performance.
ksunday1
Jan 14, 2012 03:30 PM
bigdaddyjanks
Jun 6, 2011 11:43 PM
begrdnr
May 17, 2011 02:42 PM
turbo99397
Nov 25, 2007 01:49 PM
drwalker88
Feb 16, 2007 01:18 AM
