gas smell...
Old May 14, 2012 | 11:35 PM
tripovermyego's Avatar
tripovermyego is on a distinguished road
Default gas smell...
Ok so after doing some research on here, I couldnt find anything near my problem.. I started smelling gas from inside my Blazer while its running. But you can ONLY smell it from the inside and while its running. Its not really strong but you can smell it still. The rig is not throwing me any codes or lights. Still runs good and all. Been like this for a couple of days now. Ive tried to look but cant find any visible leaks or anything. Anyone have any idea on what it could be or know what it is?
Old May 14, 2012 | 11:39 PM
volfan4's Avatar
volfan4 is an unknown quantity at this point
look at the schrader valve on the fuel rail. Mine was loose once and the smell was bad inside the cab.
Old May 14, 2012 | 11:45 PM
Hmm never thought about that!
Old May 15, 2012 | 12:17 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Yeah i get that smell sometimes also. I would also take your intake boot off and open up the throttle (not running) and smell inside there for raw gas. could possibly have a small leak in the spider.
Old May 20, 2012 | 12:42 AM
Ok so either I got used to the smell or it went away cause I havent noticed it in the last few days. Idk tho. I looked at everything you guys mentioned and i didnt see anything wrong with it at all.
Old May 20, 2012 | 07:56 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Check the vac line to the vacuum reservoir the hood. When mine is unplugged, I smell gas inside the truck.
trapperjohn4077
Jun 7, 2010 10:49 AM
chrisblaze
May 23, 2009 02:21 PM
metalhead
Mar 1, 2007 12:46 AM
hollisterdj
Dec 1, 2005 03:22 PM
ShadowHawk
29
Oct 23, 2005 01:50 AM
