Grinding Starter and P1345 Code
Old Nov 13, 2015 | 02:37 PM
LesMyer's Avatar
Originally Posted by Pastor_Pop
Thank you Lesmyer. I will keep an eye on it. Just strange that it happens every so often.
My TCC will never engage if I am going less than 45mph. Once engaged it can stay engaged to as low as 40mph if throttle is extremely light but likes to disconnect on any uphill. So if you are setting your cruise to about 45mph then it is opeating exactly as I would expect once a slight load is placed on the engine for any reason.
If you really think it is surging (and it would also surge at 55mph if this is the case), check the adjustment at the throttle body for the cruise cable. Too much play and cruise controls are known to surge. But the rpms gong up and down with the same vehicle speed in 40-50mph range is the TCC clutch.
Bet it does same thing even when you don't have cruise engaged.
Probably you are noticing this for the first time because the TCC clutch has not been allowed to engage before due to pending misfires or P1345 code setting. Now you have fixed your distributor and TCC is finally locking up - so you are noticing something new. Am I right?
Old Nov 16, 2015 | 02:53 PM
KingRanchkennels's Avatar
KingRanchkennels is on a distinguished road
Hello everyone, I have been browsing the forums and would like some advice.
Currently own a 1998 Blazer, 4.3 vortec, 4wd, 207k miles. A few weeks ago my starter made a terrible noise. I found that the outside mounting bolt had broken. I replaced the bolt and the starter made a grinding noise nearly every time. So I used some shims. No matter how many I used l, the grind would not stop. So I then used a new starter from AutoZone. No shims and the noise was gone for a day, then came back. I took the blazer to a mechanic friend and he placed a washer on the outside bolt to shim it closer and that worked for a day before the noise returned. My friend also said that I have a P1345 code and that means my distributor is misaligned. He moved it but couldn't get it to take, so that needs to be replaced. My friend believes that a new distributor will help engine performance and solve part or most of my hard starting problems. Do any of you have any thoughts or advice? Also, a friend of mine through the church has offered to give me a 2000 Bravada to use as a parts vehicle. It has a major gas leak and he hasn't used it in over a year. The Bravada has a 4.3 vortec and is also 4wd. Will most parts be compatible?
Sorry for the long post. Thanks for any help and God bless.
Most of it should be the same parts , the stuff you have mentioned anyway .
Old Nov 24, 2015 | 07:30 PM
Pastor_Pop's Avatar
Pastor_Pop is on a distinguished road
Now that the temps have dropped and we've had our first snow here in Michigan, I have a question about the operating temp. I have heat, but the temp gauge only seems to get up to barely half way between 100 and 210. This can't be normal. At idle the heat feels warm but not hot. After driving for nearly an hour today at around 45mph, the temp still didn't hit even half way between 100 and 210. The heat felt OK though. Think it could be a thermostat stuck partially open?
Old Nov 24, 2015 | 07:41 PM
I forget the name of it right now but they make a stat that stick open when it fails , maybe you have one in this truck ?
Old Nov 24, 2015 | 08:12 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Sounds like it's time for a back flush and new thermostat... Not that bad of a job, esp if you get your mechanic friend to help you out.
If the radiator is original, the drain peacock will open with a 1/4" ratchet. But it will take forever. Just remove the lower radiator hose
I'm pretty sure 195 degrees is OEM for the thermostat. I would have your friend pressure test the cooling system before and after the flush and top it off with a new radiator cap.
Hope that helps!
Old Nov 24, 2015 | 09:37 PM
Pastor_Pop's Avatar
Thanks for the tips guys! My Dad is handy with a wrench and I've tackled thermostats in other vehicles. I will definitely do a back flush and swap out the stat. I'll keep you all posted. So thankful that I found this forum!
Old Dec 1, 2015 | 06:56 PM
brain7734's Avatar
brain7734 is on a distinguished road
I would have the trans looked at if it's surging a couple hundred RPM. Lesmyer is right, the torque converter is going from lock-up to non-lock up (clutch engaging and disengaging). Every so often should be OK, but other than once-in-a-blue-moon, the torque converter clutch can be damaged. Just scan the ECM and see if there is any TCC solenoid, PWM, or any other trans related codes.
Jason10476
Sep 27, 2021 10:27 PM
joethejman4us
Feb 16, 2010 09:25 AM
96Ls4Dr
Jan 3, 2008 09:03 PM
4x4willywill
Dec 23, 2007 04:33 PM
Mr Blazer LT
Jan 17, 2007 11:25 PM
