had to pull oil filter mount and lines...anything else needed?
Old Jan 20, 2013 | 01:17 PM
Fullsizeon38s's Avatar
Fullsizeon38s is on a distinguished road
Rock auto might have them. Pull the part number from there. Ill look around for you.
couldnt find anything on rock auto...thanks man!
Old Jan 20, 2013 | 01:24 PM
xgiovannix12's Avatar
what are you driving ? Year model and motor?
Edit: I got the information from the other thread https://blazerforum.com/forum/lighti...et-part-76654/ I suggest to keep all the information for the same issue in the same thread.
Old Jan 20, 2013 | 02:05 PM
1994 chevy full size 2 door blazer with 5.7 350
sorry...other thread was strictly to try and have help finding the part or part #...
Old Jan 20, 2013 | 04:26 PM
Every thing im finding is aftermarket to add a cooler. you might wanna try your local auto parts Then its off to the dealer if you cant find one.
Old Jan 21, 2013 | 02:38 PM
yea that's all I as finding also...thanks for your help man!
Old Jan 22, 2013 | 07:01 PM
turns out it was a discontinued part, luckily a few dealers had a few on the shelf. since it was discontinued I was able to get it for $105! plus shipping of course
Old Jan 22, 2013 | 08:02 PM
Pricey Did it come with the gasket and all ?
Old Jan 25, 2013 | 06:14 PM
came with o ring but I bought the o ring and gasket also
but I have bad news, I got the new part and the oil cooling lines on the new part are on a different side, and have no clearance for use.
but on my old adapter, those same holes are there, but plugged. and the place where my oil cooling lines need to go is solid on my new one, do yall think I can plug the holes on the new one and take the new and old one to get drilled out and tapped to match?
Attached Thumbnails had to pull oil filter mount and lines...anything else needed?-d613e266-ad6d-4497-bdc4-26d737f6d81a-3391-000003434b7b1244.jpg   had to pull oil filter mount and lines...anything else needed?-66382eb3-bb60-4af4-912c-2a74a30cd6e2-3391-000003434eddb979.jpg
Old Jan 25, 2013 | 06:19 PM
I would see if the dealer can get the correct one. your talking about a 100 buck part your experimenting with.
Old Jan 25, 2013 | 06:24 PM
im going to go talk to them tomorrow, but it honestly seems like that's what was done on the old one, in the holes you can see the swivel marks from a what looks like a drill bit. and the old one has the exact same holes just plugged. I own a pipe bending and fabrication company so metal work is no problem
