Hard 1-2 shift
Old Apr 29, 2017 | 06:03 PM
Ej46Blazer's Avatar
Ej46Blazer is on a distinguished road
Default Hard 1-2 shift
Hi everyone,
I've tried looking all over for info on my problem but couldn't really find anyone with the same symptoms.
My auto trans is shifting VERY hard and late on the 1-2 shift. This only happens when everything is up to operating temperature. It's much worse when the shift happens at lower rpms. The blazer has 108000 miles on it. Any ideas?
Thanks!
Old Apr 30, 2017 | 04:44 AM
Transman304's Avatar
Ck engine light on? Probably has code present. What year vehicle? 96 or newer will have P0741 or P1870 these are slip codes for torque converter or transmission component slipping. The computer is commanding high line pressure to compensate for slip. Giving you a harsh shift. Very very common problem.
Old May 1, 2017 | 08:35 AM
chris015's Avatar
bad tps will do this too,at least on the 92-95 models i know. it'll slam into gear.
Old May 6, 2017 | 10:34 AM
Ej46Blazer's Avatar
Thanks for the responses guys (I've been without internet for a while). Replacing the worn valve body seemed to have done the job!
Digitized
Jan 12, 2014 12:07 PM
dkk1661
Oct 7, 2009 10:55 PM
hammer3478
Mar 12, 2008 03:49 PM
spunbearing
Sep 26, 2007 05:01 PM
brock
Aug 15, 2007 11:45 PM
