Have any1 put a 700r4 transmission in a 96 blazer
Old Sep 9, 2008 | 03:17 PM
radje00's Avatar
radje00 is an unknown quantity at this point
Default Have any1 put a 700r4 transmission in a 96 blazer
I HAVE A 96 BLAZER ZR2THAT HAD A 4.3 VORTEC AND A 4L80 TRANS IN IT. I TOOK THE 4.3 OUT AND PUT A 350 VORTEC WITH A 700R4 IN IT NOW. BUT THE ONLY THING IS THAT I'M STUCK. I DID EVERYTHING BUT THE ONLY PROBLEM IS THAT THE OLD CROSSMEMBER FOR THE TRANSMISSION, I CANT USE IT. SO NOW I HAVE TO FIND ANOTHER CROSSMEMBER. I WAS TRYING TO ASK ANY ONE ON HERE HAVE THEY EVER DID THAT. CAN I GET ONE OFF ANOTHER TRUCK OR DO I HAVE TO GET ON MADE? ANY HELP
Old Sep 9, 2008 | 03:49 PM
Default RE: Have any1 put a 700r4 transmission in a 96 blazer
First, calm down with the CAPS lock man... Second, please do not post the same question in multiple sections.
There are subtle differences in the length of the transmissions. Your 96 had a 4L60E transmission to begin with. You will have to modify the cross member to work with the different engine/transmission combo. You could have lined everything up with both engines/transmissions next to each other and fabricated the motor mounts to account for the difference in transmission lengths, but if you purchased v8 mounts for an s-series, then you will have to modify the cross member as I already stated.
Old Sep 9, 2008 | 10:49 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Your gonna have to make your own crossmember not really that hard to do. I think if youdid that engineswap as long as you can weldthis will be no problem.
98Ltblazer
Apr 22, 2010 06:57 AM
radje00
Sep 17, 2008 12:32 AM
flowmasta
Jul 26, 2006 01:16 AM
djbass_mekanik
Suspension Tech
Jan 21, 2006 04:23 AM
FatRyan
May 22, 2005 01:42 PM
