head gasket or manifold gasket
Old Apr 23, 2010 | 04:59 PM
LJ809's Avatar
LJ809 is on a distinguished road
Default head gasket or manifold gasket
My blazer started runnig hot on the way in to work not boiling over just hotter then usual also started running rough. I let it cool added anti freeze and drove it home. I saw no visible signs of a leak anywhere so I checked dip stick found coolant in engine oil. I thought head gasket but after reading posts on the forum realized it could be manifold gasket. My concern is that my oil level on the dip stick was at least 3" above full. 175000 on motor is there hope or should i look to rebuild motor. thanks
Old Apr 23, 2010 | 07:00 PM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
Yeah it is defiantly your Lower intake gasket.... is the motor knocking at all? if not it may not have done much damage and you can get by with draining the oil and antifreeze and changing the LIM gasket.. then when you get done with that you can add like 4 quarts of oil and a can of seafoam and let it run up to operating temp and then drain that and replace with 5 quarts of oil
Old Apr 23, 2010 | 08:45 PM
My vote would be LIM as well. And agree that if it isn't making unusual noises *yet*, then it may be ok.
Old Apr 24, 2010 | 01:49 PM
LJ809's Avatar
No the motor sounds ok. thanks for the info i've also picked up some real good info from previous threads on the forum including the d-tips step by step manifold removal, and to use the better fel pro gaskets.I'm not really looking forward to doing it but it doesn't look to difficult and it beats spending $550 thanks again
Old Apr 24, 2010 | 02:40 PM
old skool luvr's Avatar
good luck.
be sure to let us know how you made out.
Old Apr 24, 2010 | 03:30 PM
scott_wheels's Avatar
scott_wheels is on a distinguished road
i had the exact same problem thaught it was that to0 but these vortec motors are known for there head gaskits going i heard from lots of people it is the anti freeze they used from factory???? not sure tho. but anyways i decided to replace the head gaskit anyway and it turned out that was the problem gaskit gone and heads needed to be shaved!!
Old Apr 25, 2010 | 06:02 AM
Nvidia78's Avatar
Well its good that the motor sounds good, good luck on replacing the LIM gasket and let us know how everything turns out
limited edition 1
Jan 27, 2023 11:07 AM
foanc
May 31, 2015 02:00 PM
Epikos
Nov 30, 2011 09:24 PM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
