Help 04 blazer misses after warm up.
Old Jul 1, 2012 | 03:20 PM
Paulywog05's Avatar
Paulywog05 is on a distinguished road
Exclamation Help 04 blazer misses after warm up.
Hello all. My 2004 Blazer has a problem with missing after it has ran for a spell.
When I first start it up it will run fine with no issues. If i turn it off and let it sit for 20 min or longer it will sputter and miss after I start it up. I sometime gets bad enough that it will make the check engine light come on or sometimes flash.
I just had the lower intake gaskets replaced and had the other gaskets checked and they all seem to be ok. It did this before and after I had the gaskets replaced.
I bought it used in February so i'm not sure about any service it has had in the past. It has 86,000 miles.
Thank You
Old Jul 29, 2012 | 11:14 AM
rodeofan5656's Avatar
rodeofan5656 is on a distinguished road
seems like the problem i had on my 1992 Dodge pickup. i never fixed the problem, cause i spent too much tryin to figure out what was goin on. i replaced distributor cap and rotor, plugs, and that kinda stuff, throttle position sensor, etc. i never replaced the MAP sensor (Manifold Absolute Pressure), which was the last thing to replace. i didnt replace it cause it was $195 for a simple sensor. check you MAP sensor if you have one, your MAF (mass air flow) and ignition timin. hope this helps alittle!
Old Jul 29, 2012 | 12:07 PM
necropenetrator's Avatar
necropenetrator is an unknown quantity at this point
id check for spark plug wires grounding out....look for water on the engine, sometimes a heater core hose will puncture and wont spit water till the engine is warm.
Muddigger86
18
Sep 28, 2015 12:04 PM
toddyboy469
Apr 9, 2015 12:48 PM
ajwright
Jan 12, 2009 04:27 PM
Inferno
Oct 22, 2006 08:56 PM
ivannj
Dec 19, 2005 07:54 PM
