Help!!!
Old Jan 24, 2010 | 03:42 PM
youngtearz's Avatar
youngtearz is on a distinguished road
Default Help!!!
1999 blazer lt 258kms on it.. when i floor the truck to pass someone it drops a gear but then feels like its in neutral. I wanted to go the cheap way so i just put spark plugs in, the one behind that steering shaft is a pain in the the ****! i didn't change the wires.. i got the truck out of 4wd and back too 2wd manually, what could this problem possible be?? (p.s. : the y pipe that goes to the cat just started leaking, so could the cat possibly be the issue here?)
any advice would help!! thanks!
Old Jan 24, 2010 | 07:04 PM
22mr2's Avatar
22mr2 is on a distinguished road
it sounds like your transmission clutches are starting to go or its low on fluid. Check your fluid level and the condition of the fluid. If its brown and smells burnt, it may be time for a new transmission. Id doubt its a plug or a cat problem, a plugged cat wouldnt feel like it was in neutral, it would feel like a power loss. A bad plug would most likely spit and spudder and most likely blow a check engine light for a cylinder misfire
Old Jan 24, 2010 | 09:46 PM
Qumodo's Avatar
Qumodo is on a distinguished road
My 89' does the exact same thing. it is 100% your tranny. does it suck going uphills too? your going to need to get your tranny rebuilt or get a newer one out of a boneyard. a rebuild is going to run you around 1K and a salvage tranny will be around $700ish. hope this helps.
Old Jan 25, 2010 | 09:50 PM
youngtearz's Avatar
Default ...
yes i think the tranny clutches are worn, i think imma drive it like this till summer then get a used tranny out of a scrap yard, u pull it u save type deal.. thank you.
Old Jan 25, 2010 | 11:38 PM
sparky672's Avatar
sparky672 is on a distinguished road
Originally Posted by youngtearz
... so i just put spark plugs in, the one behind that steering shaft is a pain in the the ****...
BTW - you can more easily get to all six plugs by pulling off the front wheels and going straight in under the wheel wells. You'll still need a swivel to get the one by the steering shaft but it's so much easier to see it this way.
