HELP ASAP.. COOLANT TEMP SENSORS
Old Oct 14, 2008 | 11:10 AM
Default RE: HELP ASAP.. COOLANT TEMP SENSORS
EGR valves can hang open causing drive-ability concerns (performance, mileage, etc) without triggering a CEL.
Old Oct 14, 2008 | 04:13 PM
salvy's Avatar
salvy is an unknown quantity at this point
Kyle,
bought the gasket w/the screen list was 32.00 my cost 16.50 anyway I pulled it out, There was carbon built up but, not as bad as I thought it would have, anyway I cleaned out the ports on the intake, ran it with it off to blow out the crap, then took the EGR put it in my vise, filled it w/cleaner let it soak, there was a rough seat in the plunger until I cleaned it out, plus blew out residue w/my compressor, put it back started it up idles smooth as a top. Now gotta see if I get some better mileage out of it. Thanks Very Much.
Old Oct 14, 2008 | 07:58 PM
Glad to help!
Old Oct 16, 2008 | 02:59 PM
chevygulr84's Avatar
chevygulr84 is an unknown quantity at this point
Would a 96 have 2 sensors? My te,p/ gauge hasn't worked since I bought the truck - very annoying and dangerous. I've changed the reg temp gauge and done a radiator flush - same. Several mechanics are stumped as well - any suggestions?
Old Oct 16, 2008 | 03:42 PM
salvy's Avatar
I really don't know, one the guys here helped me out with mine, on my 2000, it has only 1. Best to ask Kyle, he know's these very well.
Old Oct 16, 2008 | 09:42 PM
If you have a single wire sensor on the driver side cylinder head near the exhaust manifold, then you will have another sensor.
Old Oct 18, 2008 | 01:30 PM
rogggg1020's Avatar
rogggg1020 is an unknown quantity at this point
then with that bein said wouldnt i have 2 sensons as well too cause i had a single wire sensor there or is mine to old??
Old Oct 18, 2008 | 01:31 PM
There is no need for another sensor on your truck, rogggg. You have no true PCM. At least not in the sense that TBI, CPI, and SCFI trucks do. I do not believe that the TBI trucks have two sensors either.
Old Oct 18, 2008 | 02:21 PM
rogggg1020's Avatar
koolness thanks swart i got some pics of my truck now and some pics of wire plugs too if your intrested
89Recon
15
Dec 24, 2011 07:02 PM
eric_marchi
Mar 7, 2011 08:57 PM
zakm0n
Jan 9, 2011 07:31 PM
ClueMeIn1989
15
Aug 10, 2009 07:26 AM
LittleDan911
Dec 14, 2005 07:12 PM
