-   -   help crank but no start (https://blazerforum.com/forum/engine-transmission-35/help-crank-but-no-start-106367/)
drdustin39 Mar 19, 2024 01:47 PM
Ihave a 2001 4x4 blazer 4.3. when i bought the ride it started just fine, ran for 30 minutes and i shut it off. went back 2 days later and wouldnt start. replaced distributor, plugs icm. still no start. when i turn off the key it acts like its trying to keep cranking.kinda like the last seconds when u r running out of gas. it isnt pulling any codes. can someone offer any helpful tips plese.thanks
GeorgeLG Mar 19, 2024 04:29 PM
So when you try to start it the starter engages and the motor cranks at normal speed and with normal sound, but then no evidence of trying to run if even poorly. Then when you stop cranking, the starter keeps running or the starter stops and the engine is dieseling for a few seconds (running crappy with no ignition source)?
George
drdustin39 Mar 19, 2024 09:30 PM
I
It keeps dieseling. It's getting spark and fuel but wint start.
GeorgeLG Mar 20, 2024 11:14 AM
Crank but no run is a common problem. A fuel injected vehicle dieseling at key off especially given that it did not run before hand and heat up the cylinders is rare. So lets get to work.
  1. Where and how did you check for spark?
  2. You need to perform the fuel pressure/leak down test in the sticky. I suspect a leaking fuel injector
  3. Do you have a recent compression test?
  4. Was anything done before this that may have affected the ignition timing?
  5. Will it temporarily start with starting fluid or gas in the throttle body?
George
drdustin39 Mar 20, 2024 07:34 PM
Holding fuel pressure at 58 to 60. Can't hear leaking injectors, fuel pump working , temporarily starts with starting fluid, confused really.
GeorgeLG Mar 20, 2024 07:42 PM
Is it possible that you have some bad gas in the tank? One way to check this is jumper the fuel pump and pump some gas out of the schrader then try that instead of starting fluid.
How well does it run with starting fluid for that short time?
If it runs good on starting fluid and some of your own gas in the throttle body then you probably have an injector problem. Do you have a noid light?
George
drdustin39 Mar 20, 2024 10:27 PM
It ran for may e 5 seconds. No no noise light.
