Help me
Old Jan 16, 2022 | 02:04 PM
Tammy Leach's Avatar
Tammy Leach is on a distinguished road
Default Help me
HELP!!!
I have a 96 jimmy that I need help with. I was driving down the road and it just quit on me. It will start if I pour gas in intake but won’t stay running. I have gas and crank and fuel pressure but injectors not opening. There’s no clogged and I’ve changed fuel filter, ECM, cam sensor and don’t know what to do. I was told there’s a ground wire for injectors but don’t know where or what color, and need to fix it before it gets impounded. Can you tell me where to check for ground wires for injectors??
Old Jan 16, 2022 | 10:08 PM
GeorgeLG's Avatar
Fused power goes to the injectors on a set of 6 pink wires and then each injector is grounded (ground side control) by the ECM as each injector needs to fire. Check power and then you use a noid light to check the ground pulses from the ECM. If your injectors are really not firing and its not the fuse (ECM/Ign fuse 10) then it might be the security system disabling the injectors. What is the security light in the dash doing?
George
89Recon
Nov 9, 2011 08:09 PM
sandman6983
Sep 6, 2010 01:23 AM
Boise LCD
18
May 24, 2010 11:14 PM
mblatz2001
Aug 3, 2009 05:33 PM
mytruck2
Oct 10, 2005 12:45 AM
