Help please
hi so I bought a 2002 Chevy blazer I have to jump it to get it started smell gas when I am going if I hit the break or gas it dies on me I have replace the spark plugs and the wires they were broken in half and black I don’t think it the fuel pump I can’t find the issue
Welcome to the forum. This is the place to be to keep your Blazer on the road.
A bit of advice: When posting share the year but also if it is a 2dr or 4dr and if it is 4wd or not. If it is 4wd tell us if it has 3-buttons to control the transfer case or 4-buttons.
Most importantly, using punctuation is super helpful for us reading your posts.
You smell gas when it is running and the spark plugs are covered with carbon? You also have trouble with it dying when at idle? I think a possible problem could be that the fuel injectors under the upper part of the intake manifold could be leaking fuel directly into the intake ports causing an overly rich condition. This could also explain the fuel smell from un-burnt fuel. Are you getting a "check engine" light? If so, go to an autoparts store and have them retrieve any codes and use them to help diagnose the issues. Be sure to share them here too. When my fuel injection "spider" was leaking one of the oxygen sensors reported a fault. I replaced it but the problem came back because it wasn't the O2 sensor failing but rather the source of the problem was the leaky fuel injectors.
Once you get things running, replacing the distributor cap and rotor will likely be a good thing to do but that is likely not the origin of the fuel smell. You could try replacing the cap and rotor now because it is so easy to do.
This time of year batteries on their last legs will falter. If it is 5 years old, it might be able to hold a charge or deliver much current anymore. An auto-parts store might be able to test it for you.
Sorry about that.... So I have a 2002 Chevy Blazer 2 wheel drive V6 4.3L Last Night I Finally got it started when I hit the gas it either shuts the whole truck off completely won’t even crank wait about 5 mins and the truck comes back I can’t get it to the auto shop
with out it breaking and there is no engine light on
I agree with Christine, start by checking your fuel pressure. Rent a tester from a parts store, and read all the posts on here about how to check pressure.
Let us know what the results are, and we can go from there
Oh good. I'm glad to hear another opinion (and that my diagnosis is not out in left-field). I could easily see a leak from the fuel injectors causing a flooding condition that would prevent the truck from being able to be restarted right away.
"My brake lights don't work, and the rear end is grinding" "check the fuel pressure and report back to us"
lac8362
13
Nov 9, 2011 10:23 PM
pigmak
Dec 29, 2009 08:59 PM
gonna get the gauges check Friday I’ll let you know
