help please with tranny fluid change 93 s10 4x4
Does the cross member HAVE to be removed to get the tranny pan off a 93 s10 4x4 Blazer?
I can access all the bolts no problem and it sure looks like i'll be able to slide to the side and down once the bolts are out.
On Chilton online it says some models need to the cross member removed, so which ones HAVE to have the cross member removed in order to remove the pan?
BrinkDiamond
03-02-2014 03:50 PM
DaleA
01-13-2009 08:50 PM
aaron1651
03-26-2008 12:18 AM
