Help! Transmission Issue :S
Hi. I have a 1996 chevy blazer ls, 4.3l v6.
I think my trans is a 4L60-E. I use the car every day, but yesterday when starting up, i've lost every gear but reverse. Engine is running properly, and i've checked trans-fluid (looks and smells good), checked for blown fuses (none), reset computer (no change), checked the trans for leaks, but everything seems fine, the cable gear shifter works properly and all. No warning lamps or anything in dash. So i seem to think it may be an electrical issue? Anyone has an electric schedule for the trans, i don't have access to a diagnosis tool just yet :( Is this likely to be an electric fault, or do i need to get it overhauled? I'm stuck, and would appreciate any reply :) |
I hate to say it, but it most likely is internal. Of the other cases where I have read about this condition, here are some things to look into:
Originally Posted by swartlkk
(Post 328837)
I see, looks like i have to split and look :( But if it was an internal fault, wouldn't there be any noise when i rev up ? And i think it's strange that everything works great, and suddenly this happens over night? |
