Here's one for ya 2001 blazer 4 door 4wd throwing codes p0300 p0102 p0452
Old Dec 26, 2019 | 06:40 PM
Edward Alexander Odren's Avatar
Edward Alexander Odren is on a distinguished road
Default Here's one for ya 2001 blazer 4 door 4wd throwing codes p0300 p0102 p0452
Ok It chuges if your light on the gas or going up hills it hates going 40 or under I've checked plugs ,wires ,dis ,vacuum ,lines ,coolent , air filters evap canister, I also had the slow pumping problem untill i zip ties the vapor canister together its the thing under the spare. I need help please
Old Dec 26, 2019 | 08:16 PM
LesMyer's Avatar
start with the P0102. https://blazerforum.com/forum/diagno...plained-28157/
Old Dec 26, 2019 | 08:44 PM
Originally Posted by LesMyer
I have checked maf its good I think I have it because I took it off a few days ago I'm replacing the valve under spare. Lots of rust but all the hoses look,great
Old Dec 26, 2019 | 09:17 PM
LesMyer's Avatar
Then you need to clear the codes and make sure what is currently the problem and what is not. ps - anything P0452 related is not going to cause a misfire and P0300 is a result of a problem, not a cause.
superfly851
Apr 16, 2013 06:56 PM
truesmack
Jul 25, 2012 05:19 PM
jetncomptech
Nov 24, 2010 03:34 PM
abadinalbany
Sep 13, 2010 11:02 AM
bjsx8f
Sep 7, 2008 09:29 AM
