high idle
Old Apr 5, 2011 | 05:20 PM
newellb85's Avatar
newellb85 is on a distinguished road
Default high idle
I have a 94 s10 with a 4.3. Bought it from a freind and he told me that it had and high idle, checked the codes and it was an iac. So i bought a new one, checked the distance of the pintol distance and installed it. Drove at 40 mph for a couple of mins and would not set. Still pops up an iac code. Does any one know what else it is, or something i can try to fix it. Thanks
Old Apr 5, 2011 | 07:46 PM
It is possible that the wiring to/from the IAC valve is damaged somewhere.
What was the specific code? If it is an idle to high code, then it could be caused by a vacuum leak.
Old Apr 5, 2011 | 10:19 PM
newellb85's Avatar
It was code 35, iac error or idle problem
had it on a scanner while driving it and it showed it was functioning while driving, but when u come to a stop or park, it idles about 1500 rpms
Last edited by swartlkk; Apr 6, 2011 at 07:29 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Apr 6, 2011 | 04:19 AM
Magmotor's Avatar
Magmotor is on a distinguished road
Long shot but manual says to disconnect the battery, leave it off when replaceing the IAC, to reset the computer. Also a bad TPS will do the same thing.
Old Apr 6, 2011 | 10:52 AM
newellb85's Avatar
Battery was disconnected, and put a new tps in too.
Old Apr 6, 2011 | 08:57 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
what is the vaccuum pressure?
mcdevin1973
Oct 5, 2014 02:52 PM
midnightryder
Dec 29, 2009 02:43 PM
need new tires
Aug 7, 2006 04:05 AM
slicker
Feb 12, 2006 09:02 PM
IceFire
Dec 7, 2005 03:55 AM
