4.3 high idle how do you adjust it?
Old Dec 29, 2009 | 02:35 PM
midnightryder's Avatar
midnightryder is an unknown quantity at this point
Default 4.3 high idle how do you adjust it?
92 s-10 blazer 4.3 high idle how do you adjust this?
Old Dec 29, 2009 | 02:40 PM
CPI or TBI?
Either way, it is controlled by the ECU via the IAC valve. Base idle air setting can be changed, but first you have to verify that the IAC valve is doing its job and that you do not have other contributing factors (namely vacuum leaks).
Old Dec 29, 2009 | 02:43 PM
it is the non vortec motor. it doesnt appear to have any vaccum leaks i did look for that. what is the iac valve an how do you check if its doing its job?
mcdevin1973
Oct 5, 2014 02:52 PM
2000TAHOEMAN
Jan 1, 2011 08:27 PM
jacobbuniger
Dec 17, 2010 03:08 PM
Bigguns72
Oct 29, 2010 06:52 PM
er.rigney
Jun 3, 2009 09:16 PM
