Hot Air and A/C Issue ...
Old Dec 2, 2013 | 11:53 AM
patoconcha's Avatar
patoconcha is on a distinguished road
Default Hot Air and A/C Issue ...
Hello Guys,
Well, im from Chile and some time ago (like 3 months) i introduced myself and my wife's Blazer 1999 4.3 (2 door).
She already ordered from USA the Rough Country 2,5" lift and contacted a local shop so they will do the labor and will add 2" body lift. She ordered new wheels and tires from USA too and some spacers to make the truck a little wider.
Now, internally, the truck is very good and well maintained, but nor A/C nor HOT AIR is working. If you turn on the heat, just cold air is coming, the flow is strong and everything, but not hot as desire, A/C is zero too.
Any tips to see what is really needed to fix this ?
thanks !!!
Pato Concha
Chile - Southamerica
(writing on behalf of "The Wife")
Old Dec 2, 2013 | 12:15 PM
Diaita's Avatar
Does it have enough coolant in the radiator? Does the A/C compressor run when the A/C is on, and when the controls are set to defrost? Is there any hissing from behind the heater controls?
Old Dec 4, 2013 | 10:46 AM
patoconcha's Avatar
Coolant is checked on weekly basis and is OK.
Compressor is not working (i hope thats the only issue with AC)
Hissing ?, no ... nothing.
AC Compressor participate on HOT AIR ?, not right ?
Old Dec 4, 2013 | 01:35 PM
Diaita's Avatar
There is probably a leak in the A/C system somewhere. There is a pressure switch in the system that will prevent the A/C compressor from turning on due to low pressure.
Does the engine come up to about 200F or 90C? Do the heater hoses get hot where they go through the firewall? Could be an issue with the engine thermostat.
Old Dec 5, 2013 | 04:39 PM
patoconcha's Avatar
Thanks a lot people.
Right now im in Mexico for a job assignment and will return home for Christmas time. I will take my wife's Blazer to a mechanic shop and let them check.
Thanks for the advices !!!
My wife is committed to work on her truck and be able to be at the ROTM or ROTY on this forum
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
nuwave
Feb 10, 2011 01:28 PM
88_s10
Jan 15, 2011 05:04 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
