How to clean EGR ports in plenum?
Old Sep 25, 2007 | 07:49 PM
riverjamie's Avatar
riverjamie is an unknown quantity at this point
Default How to clean EGR ports in plenum?
I read an older post on how to clean out clogged ports for the EGR valve. I've already clean out and vaccumed out the ports, but in the older post it was mentioned to start the engine then shut it off with the valve off to blow it out. Is it okay to do that with the plenum off?? Not sure because of the the gas and spark? Is it really needed?
Thanks
Old Sep 25, 2007 | 08:32 PM
Default RE: How to clean EGR ports in plenum?
You could always pull the fuel pump relay or the coil wire... Either will stop the engine from firing. Do which ever is easier, but I am unsure as to whether enough exhaust pressure can be created by turning the engine over with the starter only.
You could always wait to reinstall the EGR valve until you got the upper plenum reinstalled.
globalaccessacc
29
May 25, 2023 10:06 AM
taba5
Jun 14, 2010 06:27 PM
bigdaddykane93
Aug 17, 2009 02:21 AM
hondacharger
25
Aug 10, 2009 11:24 PM
boomtruck97
Jul 11, 2006 04:27 AM
