How much oil goes in a 1985 K5 Blazer 350?
Old Sep 19, 2007 | 10:17 AM
ClayKuch's Avatar
ClayKuch is an unknown quantity at this point
Default How much oil goes in a 1985 K5 Blazer 350?
I have a 1985 Blazer K5 with a 350. It has the wrong dipstick in it. I just changed the oil and added 6 quarts of oil. But the oil level is not on the dipstick yet. How much oil does this motor need?
Thanks,
Clayton
Old Sep 19, 2007 | 10:59 AM
95_4door's Avatar
95_4door is an unknown quantity at this point
Default RE: How much oil goes in a 1985 K5 Blazer 350?
If it has the original oil pan, then it takes 5 qts. If it has a larger oil pan then it may take more. If you don't put enough oil in it, the oil pump will have problems circulating it. But at the same time, if you put too much oil in it, you risk blowing out seals and causing leaks everywhere.
PROJECT85K5
Jun 23, 2013 02:40 PM
tech180
Feb 2, 2013 10:23 AM
Doctorvette
Nov 5, 2012 11:57 PM
hotrodsbyg
Jul 3, 2010 02:37 PM
naf821
Aug 8, 2007 07:19 AM
