i need help please
Old Jul 5, 2008 | 05:46 PM
keithp's Avatar
keithp is an unknown quantity at this point
Default i need help please
i have a 1995 chevy blazer 4><4 4.3 fuel injected mpfi on wednesday i stopped at store i came back and started it up it ran fine, when i put it in drive it was bogg down on me with the accelerator down-i let off of accelerator and coasted it ran okay-just not fast. when i presse on accelerator it bogged down and then to point of it dieing. i drove it home that way 20 miles away and it was rough. i get it home and turn it off-wont start at all. i let it set for two days and tried starting it it started and then i proceeded to change out fuel filter thinking it was the problem, but i cant get it to start now. after many tries and lots of smell of gas around engine compartment i am at a loss of what to do next. any help or advise is reatly appreciated.
sincerely,
PAtrick
Old Jul 5, 2008 | 07:46 PM
Default RE: i need help please
The first thing to do is a fuel pressure test. The CPI motors (not mpfi) are known for FPR (fuel pressure regulator) failures. Test the fuel pressure at the fuel pressure test port (rear driver side of the plenum near the brake booster). For a properly functioning fuel system, the pressure should be 55-60psi. Also, the pressure should not drop more than 2-3 psi after the pump has shut off.
Old Jul 6, 2008 | 03:24 PM
keithp's Avatar
UPDATE advise taken and it worked! thank you very much for your help i am forever grateful
Keith
opposedforces
Sep 1, 2011 02:59 PM
rogggg1020
Nov 11, 2008 08:05 AM
pdljr04
Aug 15, 2005 04:56 PM
blazin4eva
Jan 27, 2005 02:02 PM
