I need a new engine!!
Old Feb 1, 2010 | 03:52 PM
Luis Araiza's Avatar
Luis Araiza is on a distinguished road
Default I need a new engine!!
I am in need of a new engine for my Blazer. Where do I go about getting a new one.
Old Feb 1, 2010 | 04:44 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
Jasper engines, or if around the Nashville area Grooms engines or
Old Feb 1, 2010 | 05:37 PM
noseback's Avatar
noseback is on a distinguished road
junk yard...so many of these trucks around, or keep an eye on craigslist. alot of those people out there sell those trucks for parts or partical take off
Old Feb 1, 2010 | 06:10 PM
mr.vls's Avatar
There are many places to get an engine and prices all over the place. Depends on if you are going to remove and install. I replaced my engine with a GM factory Rebuilt and replaced myself. If you want someone else to do it the best bet would be a local engine rebuilder who will remove, rebuild and re-install. They usually have competive prices and a warranty. Junkyard engines are a crap shoot. You could get one with a lot of life left in or you might get one that is on it's last leg. The junkyard option is probaly the cheapest especially if they will remove and install as well. Your budget and time availible and the desired warranty should lead you to the best option for you. An experienced installer is a big plus in my book. This will help ensure everthing get hooked up correctly, nothing else is broken and you do not have go back because of leaks or malfunctions.
Old Feb 1, 2010 | 06:51 PM
How did you go about getting a GM factory rebuilt engine and transmission?
Old Feb 1, 2010 | 08:42 PM
mr.vls's Avatar
Any GM Parts counter. I called all the GM dealers in my area to find the best price. Even locally the price varied quite a bit. There are two engines a GM factory Rebuilt and an AC Delco rebuilt. The GM version has a better warranty. It does not matter who installs it. The engine I purchased was a GM Remanuafactored long block. Complete engine minus Intake and TBI, no sheetmetal or waterpump or fan clutch assy. But it does have heads and oil pump. Just need to transfer those items from the original engine. I have over 70K on the engine and it stills runs like new. I felt it was worth it as the warranty is covered by any GM dealer if there is a problem with the engine. I believe the warranty is 50K or 3 years. The good thing about the GM engines everthing is brought to GM specifications and any improvements are incorporated. Do a google search on Goodwrench Engines for more information. But any GM franchise can price it out for you. I did mine solo and it took me just under two weeks to remove transfer and install and fix any issues i had and then return the core. You might find online prices but the shipping costs and the core return will offset any savings you might find.
I pulled my receipt and on 12/08/03 I ordered the following engine from Dees Chevrolet: P/N 12361243 ENGLB4REM, Cost: $1701.00, Core: $200.00 On 12/29/03 I returned the core using my S15 Jimmy with the new engine.
lawclagett
Jul 16, 2012 03:36 PM
DaddysBlazer
Aug 21, 2011 08:19 PM
Stansfield
Jul 4, 2010 06:54 AM
zombiewoof
Feb 1, 2009 12:06 PM
