iac location
Old Oct 24, 2008 | 09:07 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default iac location
where can i find it on the vehicle? i looked all over on these forums and searched the internet and couldnt find anything. i want to clean the pintle thats why im asking.
thanks,
anthony
Old Oct 25, 2008 | 11:07 AM
Hanr3's Avatar
Default RE: iac location
The IAC (Idle Air Control) is bolted to the intake. Find your air filter, follow the tube from the air filter to the intake. Take the tube off, look on the side of the intake for a wireing harness. Go to Autozone, find the part by filling in your trucks specifics, year, make, model, engine. Search for IAC. Look at the picture of the part and find the same thing on your truck. It will be located close to where the intake tube attaches to the top of the engine. It will have a wiring harness attached. You may have to remove a engine cover to find it.
I dont have software to put arrows on pictures or I would post it up for you.
Old Oct 25, 2008 | 05:24 PM
ant2297's Avatar
yea i found it on the side of the throttle plate. its burried and i cant come no where close to the bottom screw. im going to try the seafoam treatment so theres no point in taking it off. i can see the pintle through the air chanel for it in the throttle plate assembly, just looks a little carboned up from the looks of it. why is everything so hard to access on this engine.
boscoedoodle
Nov 4, 2009 09:48 PM
Whutdidyousay
Oct 16, 2007 09:50 PM
jbeanz
Jul 23, 2007 02:26 AM
Mbastet99
Aug 25, 2006 09:55 PM
ron36535
Jan 23, 2006 12:06 AM
