idles fine but bogs out when u give it gas
i just put a new fuel spider, map sensor,throttle body but it still bogs out after u give it gas it idles fine any suggestions?
Originally Posted by jceney87
(Post 399142)
Idles, but won't let you drive? Bogs out, does it sputter at all?
It could be a clogged Catalytic Converter, I've seen this happen before. |
i got sixty pounds at the rail
its start a little ruff but like 5 seconds later it idles fine but once u give it any gas it starts to bog out,thank u i think thats what it is. does it need compression through it too? cuz my dad drilled a hole in it dont know y lol |
did you make 2 posts under different screen names???
no my dad mite have
try unplugging your mass air flow sensor - the engine will kick into a default mode without the sensor and if it runs better without it then have yours tested.
worked like a charm for me - mine had no power above 45 mph, valves rattleing at 3500 rpms, transmission acted like it was shot - wouldn't downshift right. |
Originally Posted by snowman5x
(Post 400987)
worked like a charm for me - mine had no power above 45 mph, valves rattleing at 3500 rpms, transmission acted like it was shot - wouldn't downshift right. That reminds me is it throwing a CEL? if so what are the codes? |
