idles fine but bogs out when u give it gas
Old Jan 18, 2011 | 06:47 PM
jceney87's Avatar
jceney87 is on a distinguished road
Default idles fine but bogs out when u give it gas
i just put a new fuel spider, map sensor,throttle body but it still bogs out after u give it gas it idles fine any suggestions?
Old Jan 18, 2011 | 09:44 PM
KM346's Avatar
KM346 will become famous soon enough
Check the Fuel pressure, Sounds like the pump is going.
Old Jan 18, 2011 | 09:52 PM
oktain's Avatar
Idles, but won't let you drive? Bogs out, does it sputter at all?
It could be a clogged Catalytic Converter, I've seen this happen before.
Old Jan 19, 2011 | 07:59 AM
jceney87's Avatar
i got sixty pounds at the rail
Old Jan 19, 2011 | 08:01 AM
jceney87's Avatar
its start a little ruff but like 5 seconds later it idles fine but once u give it any gas it starts to bog out,thank u i think thats what it is. does it need compression through it too? cuz my dad drilled a hole in it dont know y lol
Old Jan 19, 2011 | 11:05 AM
blazinloud's Avatar
did you make 2 posts under different screen names???
Old Jan 19, 2011 | 11:42 AM
jceney87's Avatar
no my dad mite have
Old Jan 23, 2011 | 07:40 AM
snowman5x's Avatar
snowman5x is on a distinguished road
try unplugging your mass air flow sensor - the engine will kick into a default mode without the sensor and if it runs better without it then have yours tested.
worked like a charm for me - mine had no power above 45 mph, valves rattleing at 3500 rpms, transmission acted like it was shot - wouldn't downshift right.
Old Jan 24, 2011 | 07:57 PM
KM346's Avatar
Good idea.
That reminds me is it throwing a CEL? if so what are the codes?
NCSurvival
Nov 6, 2014 05:36 AM
JetJock79
Dec 31, 2011 01:11 PM
Kjared2
Jul 27, 2011 05:23 PM
drodr05
Dec 10, 2010 09:00 AM
EricTrembath
Jan 19, 2009 04:49 PM
