Ignition control module question HELP
Old Aug 6, 2013 | 06:48 PM
tate456's Avatar
tate456 is on a distinguished road
Default Ignition control module question HELP
So i posted before stating that my 96 blazer was randomly cutting out going down the highway for a second or two and then catching itself and running just fine i tested the ignition controll module and it did test bad but the truck runs can this really be my issue or is there something more i should be looking for
Old Aug 6, 2013 | 06:53 PM
rriddle3's Avatar
Typically a bad ICM manifests itself when you try starting the engine when it is hot, causing the ICM to be hot. If you had it tested and it showed to be bad, have you replaced it?
Old Aug 6, 2013 | 06:57 PM
tate456's Avatar
no because i am skeptical of this being the problem ...... being most of the time like you said the truck wont start ...my truck runs it just cuts out once in a while
Old Aug 6, 2013 | 07:09 PM
newguy's Avatar
If it test bad your going to have to change it anyway, so why not try?
Old Aug 6, 2013 | 07:36 PM
tate456's Avatar
times are tight man i dont like throwing money into to dark pits if you know what i mean
Old Aug 6, 2013 | 07:39 PM
newguy's Avatar
understand
Old Aug 6, 2013 | 08:38 PM
Crackers's Avatar
Crackers is on a distinguished road
The ICM testers are fairly comprehensive. The testers have no way to "judge" if it will still work, it only knows that the ICM is performing outside of its regular parameters. Being out of its regular parameters doesn't mean it won't function it means it is in some stage of failure. Sort of an early warning of immenent failure.
At least that's what the guy who fixed our tester told us...
Old Aug 6, 2013 | 08:39 PM
Crackers's Avatar
Originally Posted by newguy
understand
+1 I bitch all the time about needing a cheaper hobby. LOL I've got several, and they're all expensive.
Old Aug 6, 2013 | 09:02 PM
tate456's Avatar
lol my hobbies are motorcycles and fishing and since i bought a chevy its become more exspensive than both
Brian5792
Oct 24, 2018 11:34 AM
choover82
Feb 14, 2012 11:35 PM
cannibal440
Performance & Brainstorming
Mar 18, 2008 10:47 AM
USMaverick101
Oct 31, 2006 03:10 AM
USMaverick101
Oct 29, 2006 10:29 AM
