Ignition lockout switch
Old Mar 8, 2010 | 05:31 PM
jack215's Avatar
jack215 is on a distinguished road
Default Ignition lockout switch
My 97 blazer sometimes will not start until I jiggle the shifter handle. Where is the park/nuetral ignition lockout switch
Old Mar 8, 2010 | 08:07 PM
The park/neutral switch is on the side of the transmission. But I doubt that is the problem. If giggling the shift lever allows it to start and it is a column shifter, your problem is likely a failing ignition switch.
Old Mar 9, 2010 | 05:04 PM
jack215's Avatar
It is a floor shifter, It seems like when it does this there are no instrument lights, warning ring or anything until I move the shifter.
Old Mar 9, 2010 | 06:13 PM
Even more reinforcement that the ignition switch is at fault. A park/neutral switch issue will have no impact on warning lights, instrument cluster, etc.
Old Mar 14, 2010 | 04:48 PM
jack215's Avatar
Replaced the ignition switch, works great. Thanks
Old Mar 14, 2010 | 05:11 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Yeaaaaaaaa, Another Happy Member, Thanks to the Great Help on Here. Glad to Hear because most of the time Members Never tell us their problem is fixed or Resolved and we are left in "Hummmmmmmm" hope that worked for them ? Great to Know. Thank you for the INFO, This helps other Members Also.
Old Mar 14, 2010 | 07:18 PM
Glad you got it fixed!!
Old Mar 15, 2010 | 01:27 PM
Well after I reread what I had wrote, I can see you thinking I had the same problem, But no I was Just Happy for the OP and their Success. Thanks to you Kyle.
Old Mar 15, 2010 | 01:59 PM
I was responding to the OP.
Old Mar 17, 2010 | 09:03 PM
Default Ok My Mistake
Ok My Mistake, I think ? There was two replys glad you got it fixed,, but only one now ? Must Be seeing things T.J.
Brian5792
Oct 24, 2018 11:34 AM
BomBlazer
May 22, 2009 01:09 AM
triangleman
Aug 25, 2006 11:42 AM
KA3AX
May 3, 2006 03:11 AM
