Ignition Module replaced ...no Help
Old Nov 30, 2008 | 12:21 PM
flabob1's Avatar
flabob1 is an unknown quantity at this point
Default Ignition Module replaced ...no Help
I have a S10 4x4 4.3 V6 engine ( Vortex)
My engine quit , no sounds just quit. I was't getting any spark so I replaced the Ignition Module . Now i'm geting spark but it mis fires as if the wires are crossed.
I checked to see if I crossed the leads and they look good.
JUst in case I need to chek the fireing order that I have and make sure it's OK.
For a 1993 engine it should be 1-6-5-4-3-2 is that correct ?
Could a bad ignition Module change the timing or is there something eles in the system that could be bad ?
Any help I will be Thankfull for.
Bob
Old Dec 2, 2008 | 03:51 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default RE: Ignition Module replaced ...no Help
the firing order is actually 142536, and no the icm does not changed ignition timing, the distributor does. a bad icm can give you random sparks(spark when unneeded) or no spark at all. seems like you found the problem with the no spark issue, just got the wires crossed i think.
Old Dec 2, 2008 | 04:17 PM
rriddle3's Avatar
1-6-5-4-3-2 should be correct. Double check the connections of wires, they sometimes come loose. Also check the condition of the distributor cap and rotor. It might also be a bad ignition coil.
Brian5792
Oct 24, 2018 11:34 AM
tate456
Aug 6, 2013 09:02 PM
Greg Olson
May 11, 2012 07:03 PM
Tinted
Dec 1, 2011 10:01 PM
jerickso
Apr 20, 2006 11:05 PM
