injector/running rich?? 95 s10 blazer
Old Mar 8, 2009 | 07:17 PM
  #21
Back to the wetness on the passenger side of the lower intake manifold. Gas leaking will cause a miss if it is not all that bad. A straight out failed FPR will cause all kinds of serious problems, but one that is just slightly weeping fuel will cause a miss.
It is possible that you have something wrong with your distributor cap/rotor though. You did say that you had to swap back to the old one...
Old Mar 8, 2009 | 07:43 PM
  #22
rowe's Avatar
rowe is an unknown quantity at this point
im gonna get a more expensive cap tommorrow and change first,if
that doesnt do it then ill pull the spider back out and have them give me another
havent had it but a few days and have not even drove it more than 5 miles.
Old Mar 9, 2009 | 08:14 PM
  #23
rowe's Avatar
replaced the cap but it still has a miss,,,i have a question.
when i took the old spider out, i noticed that the 3 hoses on the
passenger side were hooked up front hose to front port
and second hose to third port and third hose to second port
is this correct?
Old Mar 9, 2009 | 08:39 PM
  #24
It does not matter so long as they reach. On the 96+ SCFI motors, it definitely matters, but not on the CPI motors.
Old Mar 9, 2009 | 09:05 PM
  #25
rowe's Avatar
very good,,,so i guess its down to replacing the brand new
spider,,,LOL. I HOPE I GET ONE THAT,LL LAST FOR AWHILE.
by the way my code scan tool wont link up,not sure why
its an obdII scan tool.
Old Mar 9, 2009 | 09:13 PM
  #26
Your 95 likely is not fully OBD2 compliant.
Old Mar 9, 2009 | 09:28 PM
  #27
rowe's Avatar
ok,,,so what do i need to pull codes with?
Old Mar 9, 2009 | 09:30 PM
  #28
A scanner compatible with the mongrel year that is the 95 GM vehicles (and others).
Old Mar 10, 2009 | 12:12 PM
  #29
rowe's Avatar
well i replaced the spider and checked it for leaks before
i closed it up,,still running rough,i found 2 vac hoses i havent been putting back
on,i know where the front one goes but the one on the rear of the
plinum on the passenger side i cannot find anything that
goes to it. also have a ticking in the top end probably a lifter.
wondering if that is causing the slight miss,never had one miss with a little
ticking of the lifter.
Old Mar 11, 2009 | 09:23 PM
  #30
rowe's Avatar
bump bump
