Issue starting up.
My 98 chevy blazer with 4.3 engine has been having trouble starting. It cranks fine when the key is turned but won't fire up. If I spray a little bit of starting fluid in the throttle body it will fire up no problem. This issue was every couple of days, but now it's every time I shut it off and let it sit for a little bit. Plugs, wires, distributor and fuel pump/sending unit have all been replaced. The throttle body looks clean and seems to be functioning properly. Any suggestions on what the issue could be?
samot
Mar 25, 2020 02:41 PM
okstud
Feb 14, 2009 11:56 PM
