Issue starting up.
Old May 3, 2022 | 10:51 AM
brando606's Avatar
brando606 is on a distinguished road
Default Issue starting up.
My 98 chevy blazer with 4.3 engine has been having trouble starting. It cranks fine when the key is turned but won't fire up. If I spray a little bit of starting fluid in the throttle body it will fire up no problem. This issue was every couple of days, but now it's every time I shut it off and let it sit for a little bit. Plugs, wires, distributor and fuel pump/sending unit have all been replaced. The throttle body looks clean and seems to be functioning properly. Any suggestions on what the issue could be?
Old May 3, 2022 | 06:29 PM
GeorgeLG's Avatar
Perform the fuel pressure and leak down test in the sticky and see what you get. Do you have good spark when it cranks but wont run?
George
Old May 4, 2022 | 09:39 AM
brando606's Avatar
I'm not sure if it has good spark. It cranks really well but won't start. until I spray a little bit of starting fluid in the throttle body. How do I check for a good spark?
Old May 4, 2022 | 10:31 AM
GeorgeLG's Avatar
Since it starts with starter fluid, do the fuel pressure tests first.
George
BlazeBoy95
Sep 19, 2021 03:33 AM
samot
Mar 25, 2020 02:41 PM
hotrodsbyg
Nov 21, 2010 01:17 PM
rakerley
Jan 7, 2010 07:04 AM
okstud
Feb 14, 2009 11:56 PM
