It's a bought time for a new air filter....
I thought about just building a cold air intake so, for nothing else but to open up a little air space in that corner...........
I really don't think that the C A I really does much except make a little noise.......the stock box probably produces the same volume???........ I thought about, when washing the engine down with the power washer......I would have to cover the filter or remove the pipe and plug the hole....... hmmmmm........C A I sounds like more trouble than it's worth for me...... Do you guys give bad marks for an old man that answers his own questions while he writes them out:icon_wink::icon_doh: I think Ill just go buy a new filter tomorrow.........:) |
I put a junk yard found intake on my 04 when I was going some engine work a couple years back. Looks fancy, makes a little noise when you lay into the skinny pedal, but that's about it...
For what it's worth, I'm considering putting the stock box and air filter back in it http://i113.photobucket.com/albums/n...510_202741.jpg |
The biggest thing that stopped me was, having to cover the filter before i washed the engine.......I like to experiment, but i don't like making extra work ;-).....
another thing that came to mind was the oil for the filter.......too much and you risk mucking up the MAF....... If I would happen to come across an air box in the salvage lot I might try to route some extra air hoses out to the grill area...and give that a try.... I still say the best fix is doing the new spider........my blazer has never ran better..... |
Originally Posted by don james
(Post 679727)
another thing that came to mind was the oil for the filter.......too much and you risk mucking up the MAF....... If I would happen to come across an air box in the salvage lot I might try to route some extra air hoses out to the grill area...and give that a try.... I still say the best fix is doing the new spider........my blazer has never ran better..... I've never bothered covering mine, but I also make sure to not spray right onto it. I usually have the engine running while I wash it anyhow. I use a dry filter for that reason, I don't like the oiled ones... |
So this red filter that you have is not a K&N?? if it is cloth, i guess a little water spray won't hurt, I thought all of these needed oil??...........I guess i better get with the program and find out what's new in the filter world ;-).....
after i get my seats in, I'll go back to the air box.....I may try some 1 or 1 1/2" holes and some tubing out to the front of the radiator.......I'm sure all of this has been done and I'll probably end up with an original air intake, but I like to tinker, I've been that way all my life :-) |
I have a CAI its the K&N brand I have power washed my engine several times while off roading and I just make sure I don't start it up for a few hours to give everything a chance to dry. I have never had a problem with it. As for the performance gain from it, I did notice a slight gain but not much. I mostly installed it for the noise. I am an engine nose junky.
