It's a bought time for a new air filter....
Old Aug 29, 2017 | 10:53 PM
don james's Avatar
don james is on a distinguished road
Lightbulb It's a bought time for a new air filter....
I thought about just building a cold air intake so, for nothing else but to open up a little air space in that corner...........
I really don't think that the C A I really does much except make a little noise.......the stock box probably produces the same volume???........
I thought about, when washing the engine down with the power washer......I would have to cover the filter or remove the pipe and plug the hole.......
hmmmmm........C A I sounds like more trouble than it's worth for me......
Do you guys give bad marks for an old man that answers his own questions while he writes them out
I think Ill just go buy a new filter tomorrow.........
Old Aug 30, 2017 | 09:08 AM
I put a junk yard found intake on my 04 when I was going some engine work a couple years back. Looks fancy, makes a little noise when you lay into the skinny pedal, but that's about it...
For what it's worth, I'm considering putting the stock box and air filter back in it
Old Aug 30, 2017 | 11:34 AM
don james's Avatar
The biggest thing that stopped me was, having to cover the filter before i washed the engine.......I like to experiment, but i don't like making extra work ;-).....
another thing that came to mind was the oil for the filter.......too much and you risk mucking up the MAF.......
If I would happen to come across an air box in the salvage lot I might try to route some extra air hoses out to the grill area...and give that a try....
I still say the best fix is doing the new spider........my blazer has never ran better.....
Old Sep 1, 2017 | 08:38 AM
I've never bothered covering mine, but I also make sure to not spray right onto it. I usually have the engine running while I wash it anyhow.
I use a dry filter for that reason, I don't like the oiled ones...
Old Sep 1, 2017 | 08:55 AM
don james's Avatar
So this red filter that you have is not a K&N?? if it is cloth, i guess a little water spray won't hurt, I thought all of these needed oil??...........I guess i better get with the program and find out what's new in the filter world ;-).....
after i get my seats in, I'll go back to the air box.....I may try some 1 or 1 1/2" holes and some tubing out to the front of the radiator.......I'm sure all of this has been done and I'll probably end up with an original air intake, but I like to tinker, I've been that way all my life :-)
Old Sep 1, 2017 | 10:46 AM
Brian Hinzpeter's Avatar
Brian Hinzpeter is on a distinguished road
I have a CAI its the K&N brand I have power washed my engine several times while off roading and I just make sure I don't start it up for a few hours to give everything a chance to dry. I have never had a problem with it. As for the performance gain from it, I did notice a slight gain but not much. I mostly installed it for the noise. I am an engine nose junky.
SlapBassist531
13
Feb 24, 2011 11:50 AM
ddog800
14
Feb 16, 2011 03:01 PM
mr.vls
Dec 30, 2010 08:27 PM
77Nova
Aug 28, 2010 10:38 AM
paulbaby
Aug 19, 2008 08:28 PM
