Jerking C1500 at Highway Speeds
Old Oct 21, 2012 | 05:28 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
Default Jerking C1500 at Highway Speeds
Hey guys it's been a while but I need some help. I have a 1995 GMC C1500 with the 350 and 4L60-E transmission. During highway speeds (40 mph and up) the truck jerks almost as if it is jerking like a bucking bronco. During this there is no loss in RPM or oil pressure. Only happens when I'm lightly getting on the gas to go up hill (between 1300-1500 RPM) or to pass someone. Goes away if I hammer on the gas and get above 1500 RPM. Anyone have any ideas? Any help is appreciated
Old Oct 22, 2012 | 07:19 PM
gatorboy44's Avatar
*Bump
No ideas at all? I really need some help here
Old Oct 22, 2012 | 08:13 PM
chris015's Avatar
Clean the maf with some maf cleaner. they cause all kinds of funky problems when they get dirty. hows the fluid level in the trans?
Old Oct 22, 2012 | 09:31 PM
gatorboy44's Avatar
The fluid in the tranmission is full and the fluid is nice and clean. It's weird it has the feeling of the loss of power but the rpms don't go down. I was wondering if it could be something in the rear end
Old Oct 22, 2012 | 09:35 PM
chris015's Avatar
ehh. they usually make noise though. do you have a tach or are you listening by ear?
Old Oct 22, 2012 | 09:58 PM
gatorboy44's Avatar
I've got a tach and I watched it as it did this and I didn't notice an rpm drop. Oh and it's a tbi unit so it doesn't have a MAF sensor.
Old Oct 22, 2012 | 10:05 PM
chris015's Avatar
ah cool. less pita parts to fail.
Ive got tbi as well. I do remember feeling mine pull back like that and the grey connector was loose on the coil. I had broke the clip that holds it on and it had slid partially off. See if you have the same issue.
Have you tried readjusting the detent cable for the trans?
Old Oct 22, 2012 | 10:09 PM
gatorboy44's Avatar
Nah man I'm not sure how to do that. It's a 4l60-e not a 700r4 so i don't think there is an adjustment but I could be wrong
Old Oct 23, 2012 | 06:50 AM
chris015's Avatar
Wow i had a brain fart.
this is hard to diagnose since you said the revs stay the same. I hope the trans is not slipping.
Old Oct 23, 2012 | 08:03 AM
gatorboy44's Avatar
Yeah me too I had enough problems with the last vehicle I had with a 4l60e trans. I mean it only happens in 4th gear at lower rpms under hard load during cruising speed.
