-   -   Knock sensor location '00 W Block` (https://blazerforum.com/forum/engine-transmission-35/knock-sensor-location-00-w-block%60-100871/)
Mods Jan 3, 2020 01:06 PM
For some reason the knock sensor on this truck is just laying in the engine bay on the passenger side ontop of the intake manifold, no clue why, i cant seem to find where it bolts in at. Its on a '99 Trailblazer 4DR 4WD with a 2000s block out of a similar configuration Blazer.
odat Jan 3, 2020 02:37 PM
Mods
I don't 100% know if this will apply to your year but my Morf was a 92 and this what I have.
Depending on the threads on the knock sensor some were installed in the head into the water jacket - some were in the back of the head and just screwed into the head mine has both .....
LesMyer Jan 3, 2020 02:55 PM
That's because the knock sensor mounting hole in the block changed. Early sensors (pre-2001) were 1-wire. Later sensors were 2-wire and completely different with a different size mounting hole. You should be able to find an adapter made specifically to mount the old style knock sensor on the 2001+ block. And no, you can't use the 2-wire sensor in your 1999. These sensors mount vertically next to the distributor.
early 1 wire sensor is 1/4" NPT thread
2 wire sensor is supposed to be 5/16-18 thread
Mods Jan 3, 2020 04:02 PM
Its a Pre 01 Block, early 2000 casting.
LesMyer Jan 3, 2020 05:54 PM
then look for the mounting hole close to the oil pressure sending unit.
Mods Jan 3, 2020 06:55 PM
Im not quite sure where that is either les.
odat Jan 3, 2020 07:13 PM
oil pressure sending unit is beside the distributor
LesMyer Jan 3, 2020 07:39 PM
3 Attachment(s)
Maybe these attachments will help - 1999 and 2000 have identical sensors in identical locations. 2001 uses different sensor, same location, with different size threaded hole in the block..
Mods Jan 4, 2020 01:29 PM
Located it, its right where the 99-00 Manual you linked says it is but its definitely too small for the one-wire type that was hanging on the harness, Which is odd because the receipt for the block when it was swapped several years ago says it came out of a 2000 4x4 4WDr Blazer. I dont know what the hell is going on here.
LesMyer Jan 4, 2020 09:11 PM
Maybe it wasn't original to the Blazer it came out of. Obviously engine is a 2001+. How about engine ID code on block at front of passenger side head
