Knocking sound
Old Feb 20, 2016 | 07:36 PM
Bejaran's Avatar
Bejaran is on a distinguished road
Not sure if there's metal in oil and the sound isn't coming from valve cover
Just got a short block
After I get everything put together I'm going to change oil
I'm also going to buy new head gaskets and bolts again ����
Old Feb 20, 2016 | 10:58 PM
Bejaran's Avatar
Well it's about 11pm I got the wheel wells dropped alternator, compressor, fan, radiator etc off going to call it a night and hit it hard in the morning also going to run to orileys in the morning for new gaskets, bolts, oil and filter
I syphoned out the coolant so I wouldn't have to buy more again
Want to replace oil and filter completely just in case there is metal shavings etc
Well I'll wait for some feedback on what you guys think
Old Feb 21, 2016 | 04:38 AM
newguy's Avatar
dont know how much input we can give without really being there or knowing exactly where its coming from. Hope you find the problem and are not just throwing away money
Old Feb 21, 2016 | 07:13 PM
Bejaran's Avatar
Well stuck on two hard to reach tranny bolts didn't want to have to pull tranny out dang it
Old Feb 21, 2016 | 10:01 PM
Bejaran's Avatar
Pulled oil pan off there's metal in oil
It was a connecting rod bearing on #6 (spun bearing)
Old Feb 22, 2016 | 12:27 AM
Bejaran's Avatar
Was going to buy a crankshaft kit but Appears in need a rod as well
Old Feb 22, 2016 | 03:06 AM
newguy's Avatar
good luck
Old Feb 25, 2016 | 01:00 PM
LesMyer's Avatar
Plan on replacing the radiator as the oil cooler will be containing a lot of metal. Metal has a way of hiding everywhere and you will be fixing this forever unless you get it all out of everywhere. Better yank that engine, completely disassemble, and have a machine shop check it out or simply replace the long block or with an entire used engine. Engines that have rattled the bearings need thorough evaluation by a machinist and and cleaning. Sorry! Been there. Done that! It's not going to be cheap.
Old Mar 7, 2016 | 08:02 AM
Bejaran's Avatar
Well I got another engine that just so happens to be a jasper everything is looking good so far I got it connected to my tranny just need to set it back in
But there's a big cylinder type connector that goes to the tranny and the male end fills up with tranny fluid somehow is this normal? We had disconnected the connector last weekend and I had the tranny sitting outside inside a trash bag. When we uncovered it was filled with fluid I dried as much as I could and blew the rest out with a compressor we let it sit like that and it started to fill up again so we cleaned it up again and reconnected the connector and checked it about 30 minutes later there was no fluid
Is this normal?
Old Mar 8, 2016 | 12:48 AM
odat's Avatar
pic would help
