Leaking Tranny Fluid
Old Dec 24, 2007 | 10:54 PM
joker402's Avatar
joker402 is an unknown quantity at this point
Default Leaking Tranny Fluid
Hi,
I just bought a 1987 K5 blazer with 4 speed overdrive transmission and 5.7l engine. I noticed today that it looks like when i stop it leaks a few drops of transmission Fluid. I have started the troubleshooting (just wiped off the area to check tomorrow morning), but was wondering if any one else might have some ideas.
This is what i have found out so far:
Not more than a couple drops (creates a mark on the pavement about 2" diameter, but not pooling)
Consistent in that every time i drive it and stop it drips
It is from the front of the engine compartment, below the radiator (it has a new radiator) from some silver tubing that looks like it could be a tranny cooler.
So far not a big deal, i was going to get a transmission service (drain and replace gaskets) done this weekend along with a LOF, but i figured i would put up a post and get some other thoughts.
I can post pics if any one would like to see them
Thanks
Old Dec 25, 2007 | 12:20 AM
Default RE: Leaking Tranny Fluid
Sounds like you may have either a loose line into the stock cooler in the radiator or a cracked line. The lines are pretty easy to replace on a fullsize.
Old Dec 26, 2007 | 07:21 PM
joker402's Avatar
Thanks, that is what i figured. I am going to spend the weekend getting to know the underneath of it. don't even need jacks!
bam_9_9_9
16
Nov 5, 2011 01:07 PM
98BlazerBoy
Jul 6, 2011 07:06 PM
cr8390
May 27, 2009 11:39 PM
corvette535
Dec 10, 2008 02:33 PM
