leaking tranny fluid
Old Dec 10, 2008 | 02:33 PM
  #21
corvette535's Avatar
corvette535 is an unknown quantity at this point
Default RE: leaking tranny fluid
well had to do a little hack job, but hope it works. the flared end will not push into the nut while the clip is in. i tried with the nut off and couldn't push it in, even tried with the old line and couldn't get it in short of a hammer. so i finally got the nut threaded into the tranny... i was able to push the line into that nut which was very difficult. i could not get that c-clip on not enough room for such a fine task...its hard enough without being in an impossible place. so since the line was in all the way but with out a clip, i had to jb weld that sucker in..
does any one know if whcih direction the flow is from the bottom line? toward the rad or into the tranny from the rad?
bam_9_9_9
16
Nov 5, 2011 01:07 PM
98BlazerBoy
Jul 6, 2011 07:06 PM
cr8390
May 27, 2009 11:39 PM
joker402
Dec 26, 2007 07:21 PM
