Leaking trans ?
Old Jun 2, 2020 | 12:36 AM
Pappy1952's Avatar
Pappy1952 is on a distinguished road
Default Leaking trans ?
I have a 1998 Chevy Blazer 4x4 4.3 engine. I am having a problem with the transmission leaking fluid out of the breather tube attached to the Dip stick tube. I trace the line to a 3 way vacuum valve on the top drivers side of the tranfer case. It has 3 vacuum lines going to it and is pulling fluid from it through the lines , they are vacuum lines and I assume they shouldn't have fluid in them at all. I replaced the valve because I figured it was bad and letting fluid come through, That didn't help. The valve I think is for the shifting of the 4high and low, just wondering if maybe the new valve was bad which I doubt but could be I guess,or it isn't supposed to have fluid where the valve is and has some internal problem with the transmission/Tranfer case. Thanks, BY the way love this car, had it since 2000.
Old Jun 2, 2020 | 09:18 AM
Transman304's Avatar
Welcome to the forums, the most probable cause is a failed input seal on transfer case. Very common issue that lets transmission fluid enter transfer case and getting trapped to the point it is overfilled and will push fluid out breather and into places it shouldn’t be. Pretty straight forward repair but beware it can get really messy really quick. Best way to confirm the issue is to remove the fill plug on Tcase and see if fluid pours out. Just be ready with a pan and rags. Have you been adding fluid to transmission on a regular basis?
Brad
Old Jun 2, 2020 | 07:03 PM
Pappy1952's Avatar
Thanks, don't drive it much so haven't added much fluid, is the filler plug on the driver side of the tranfer case?
Old Jun 4, 2020 | 09:36 AM
Yes the fill and drain are on the drivers side rear of Tcase.
Brad
Old Jun 23, 2020 | 05:21 AM
Pappy1952's Avatar
Thanks Brad, it was the seal, got it repaired yesterday, wasn't to bad a job, I have done a lot worse. Also the check engine light had been on but went out when I road tested it, only thoughts I have on that is it was sucking trans fluid into the engine and setting off the light,I had noticed a fluid smell when I was driving it before and now I don't , not sure that's the case but it's out all the same. Thanks again.
Mark
Old Jun 29, 2020 | 04:54 PM
Thanks for posting the results! Always nice when someone else can follow a post to completion. Glad it worked out.
Brad
Old Jul 1, 2020 | 05:05 AM
Pappy1952's Avatar
Thanks for the info, I may have figured it out sooner or later but the info really helped me move along much faster.
Mark
razman
Dec 30, 2014 10:14 PM
JasonGoneFishing
15
Dec 17, 2014 09:24 PM
builder125
Apr 17, 2011 09:20 PM
litterbug
Mar 6, 2011 04:28 PM
Senshi09
Sep 7, 2010 07:32 PM
