Leaking transfer case
Old Sep 28, 2009 | 02:33 PM
CamaroBlazerguy's Avatar
CamaroBlazerguy is an unknown quantity at this point
Default Leaking transfer case
My transfer case has been leaking all over my driveway. I was wondering does lucus or anybody make a stop leak for them? Thanks
Old Sep 28, 2009 | 02:45 PM
Why not replace the affected seal?
Old Sep 28, 2009 | 07:28 PM
its not coming from a seal. Its hard to explain without putting a picture up, ill put one up tomarro. Its coming from the center of the case where the two halves of the case meet up.
Its in my 95.
Heres a pic I found off google of the same case
http://www.mautofied.com/adphotos/10...0915143715.JPG
Old Sep 28, 2009 | 07:51 PM
If it is actually coming from between the two main case halves, then the only solution is to remove, disassemble, and reseal this location. It does not have a gasket from the factory, it is just RTV sealant. As such, I doubt any seal aid additive will help because they generally work by causing the rubber in a seal/gasket/whatever to swell.
The two surfaces are held pretty flat when machined so RTV is good enough. Sounds like someone may have had it apart and did a crappy job of cleaning the surfaces before putting it back together.
Old Sep 28, 2009 | 07:57 PM
Thats what I was afraid of. lol It was never apart, I know this because my dad bought the truck new.
Flyfishen
Jun 18, 2019 11:22 AM
wadespen
Jun 5, 2011 08:14 AM
86k5
Feb 4, 2011 02:47 PM
J.Calderon
Nov 1, 2009 06:01 PM
rustybeast
Nov 22, 2006 12:19 AM
